Release Notes 2024.1
Security fixes
KEYS-31073: Fixed improper initialization weakness in relation to BIP file parsing
KEYS-31074: Fixed improper input validation weakness in relation to BIP file parsing
KEYS-31198: Fixed DLL planting vulnerability in relation to BIP file parsing
KEYS-31740: Fixed improper input validation weakness in relation to BIP file parsing
More information at Luxion CSIRT and PSIRT.
New Features
KEYS-31218: Added a quick-menu to script ribbon button
KEYS-30655: Added new “Sharpen“ Image Style effect
Improvements
KEYS-30338: Improved the performance of GPU mode
KEYS-31202: KeyShot, Network Rendering, and the KeyShot Viewer will now install versionlessly
KEYS-30423: Made improvements to the look of AxF Measured Materials
KEYS-31069: Added support for the following CAD versions:
CATIA V6 / 3DEXPERIENCE 3D Read: R2024x
Solid Edge 3D Read: 2024
SOLIDWORKS 3D Read: 2024
UG NX 3D Read: NX 2306 Series (until 23067000)
KEYS-30631: Minimum required GPU driver version has been updated to version 535 or newer
KEYS-31220: Removed the function to Upload to the KeyShot Cloud Library
KEYS-29410: Added support for Roughness Textures in Volumetric AxF materials
KEYS-29412: Added support for Specular Normal textures in Volumetric AxF materials
KEYS-30495: Removed Flash video output format
KEYS-30743: Removed Alias import on Mac
KEYS-30836: Silent installation can now specify use of subscription license
KEYS-30908: Added support for Rhino 8 files
KEYS-31188: Updated RAL color palette to version 2024
KEYS-31266: Added compression of scenes
KEYS-31509: Only enable arrow keyboard shortcut for environment brightness/contrast adjustments in the real-time view
Bugs
KEYS-31009: Fixed a memory leak with legacy textures
KEYS-30708: Fixed a crash in Material Templates when using special characters
KEYS-30861: Fixed occasional crash when rendering very high resolution images
KEYS-31092: Fixed a bug that caused the realtime view denoiser to show an old image
KEYS-31499: Fixed a crash that could occur when unlinking materials
KEYS-31507: Fixed a bug that caused luxgetRenderOptions() to return incorrect information
KEYS-27707: Fixed an offset between the mouse and the UI in the Touch-Friendly presentation mode
KEYS-30466: Fixed an issue with incorrect region
KEYS-30739: Fixed an issue that caused Texture Area Lights to output too much light in GPU mode
KEYS-30756: Added support for displaced geometry in FBX exporter
KEYS-31005: Fixed a bug that caused the minimum size of the Project panel to be wider than intended
KEYS-31013: Fix rare crash when deleting parts in the scene tree
KEYS-31016: Fixed a crash when creating Render Passes with a large number of hidden objects
KEYS-31119: Fixed crash in FBX export
KEYS-31163: Fixed a bug that caused reloading the Frontplate image to not work
KEYS-31175: Fixed an issue where the alpha of Frontplates got premultiplied
KEYS-31199: Improved responsiveness of the realtime view when adjusting materials
KEYS-31245: Fixed a bug that caused the Geometry View Camera to be incorrect after model import
KEYS-31286: Fixed a bug that caused "Use Target as Pivot" to not update the camera correctly
KEYS-31388: Fixed a bug that caused materials to be initialized with black colors when added to the scene
KEYS-31500: Fixed an incorrect Shadow calculation for texture scattering mediums in GPU mode
KEYS-31521: Fixed a bug that caused textures to be UV mapped incorrectly
