Release Notes 2024.2
Security fixes
                                            KEYS-31749:Fixed an issue where invalid input during BIP file parsing could cause memory to be freed twice (use-after-free) (ZDI-CAN-22515)
                                            KEYS-31744:Fixed an issue where invalid input during BIP file parsing could cause an out-of-bounds memory read (ZDI-CAN-22449)
                                            KEYS-31557:Fixed JT file parsing out-of-bounds vulnerability (ZDI-CAN-23163)
                                            KEYS-31556:Fixed X_T file parsing out-of-bounds vulnerability (ZDI-CAN-23124)
All security fixes can be found at Luxion CSIRT and PSIRT.
New Features
                                            KEYS-31538:Rendering will now be paused in the background while Re-Tessellate tool is open
                                            KEYS-27293:Added support for animations in gLTF import
                                            KEYS-31530:Added option "Select Group" to Scene Tree, which selects the parent group
                                            KEYS-31750:Added function to "lock-in" to an axis in Move Tool by using hotkeys or radio buttons
                                            KEYS-30439:Added new preview workflow for uploading to Web Viewer
                                            KEYS-31272:Added support for Texture input to Camera Aperture Shape
Improvements
                                            KEYS-31571:Users will now be asked whether to link colors with the same name when applying a Color from the Library
                                            KEYS-31910:Updated support for the following formats -
                                                    CATIA V5 3D Read: V5-6R2024
                                                    Parasolid 3D Read: V36.1
                                                    UG NX 3D Read: NX 2312 Series (until 2312.4000)
                                            KEYS-31792:"Link Materials" in materials list now links to right-clicked material rather than the first selected.
                                            KEYS-31687:Added "Depth" parameter to Cylinder texture Mapping Type
                                            KEYS-32015:Added support for importing SketchUp 2024 files
                                            KEYS-31794:Material Graph will now automatically update when user selects new material for editing
                                            KEYS-31783:Improved layout of the Move Tool widget
                                            KEYS-31590:"Cloud Library" button will now always open in external browser
                                            KEYS-31505:In Geometry View, selecting Cameras on Camera Keyframe path, will now select the corresponding Keyframe
Bugs
                                            KEYS-32617:Fixed a bug where the incorrect image style was used.
                                            KEYS-32791:Fixed an issue that caused incorrect normals after saving the scene
                                            KEYS-31768:Fixed an issue with camera states being reverted when switching back and forth between CPU and GPU modes
                                            KEYS-31246:Fixed warning in log when enabling Panoramic or Stereo Camera lenses
                                            KEYS-31774:Fixed a bug that prevented the Cloud library downloading to KeyShot in external browsers
                                            KEYS-31127:Fixed indexing of Color Names when dragging and dropping a multi-selection of Colors
                                            KEYS-31799:Fixed a crash when opening Color Mode
                                            KEYS-31977:Fix crash when selecting many triangles in split surface tool
                                            KEYS-31735:Fixed a crash that occurred when using Geometry Tools on certain geometries
                                            KEYS-32237:Fixed Area Light on Flake Geometry causing a crash in GPU mode
                                            KEYS-32014:Fixed GPU being detected in TCC only systems
                                            KEYS-31737:Fixed a GPU mode crash exit with certain geometries
                                            KEYS-31574:Fixed Image Style list being re-ordered after Save and Load of Scene
                                            KEYS-31817:Fixed a crash that could occur when taking over a session
                                            KEYS-31379:Fixed deactivation of license getting stuck while uninstalling a Beta build
                                            KEYS-32163:Fixed Axalta Paint color tweaker not working correctly
                                            KEYS-32012:Fixed Anisotropic Material input not working consistently in GPU mode
                                            KEYS-31994:Fixed hitbox of items in Scene Tree
                                            KEYS-31769:Fixed a crash in Network Configurator when switching languages
                                            KEYS-31448:Fixed an issue where aborting tasks on paused workers could sometimes prevent them from resuming correctly
                                            KEYS-31434:Fixed progress bar incorrectly showing 0% in Render Output dialog
                                            KEYS-31268:Fixed issue that caused Global Illumination to not update correctly on material changes
                                            KEYS-32570:The geometry is duplicated and KeyShot does not crash
                                            KEYS-32373:Fixed KeyShot not remembering window state correctly on Windows
                                            KEYS-31853:Fixed warning in log when interacting with UI Splitter in HDRI Editor
                                            KEYS-31688:Fixed Translucent Material Samples slider being able to go below 1
                                            KEYS-31449:Increased maxiumum animation window height on small screens.
                                            KEYS-31784:Fixed the issue of empty presentations showing on the drive, when the user is out of Drive storage.
                                            KEYS-32455:Fixed a crash when loading scenes with a Camera Keyframe orbit animation in Headless Mode
                                            KEYS-32200:Fixed a crash that could occur when exiting GPU mode
                                            KEYS-32199:Fixed a crash in Welcome Window when selecting a scene
                                            KEYS-32198:Fixed a crash that could occur in the License Wizard when creating a Request file
                                            KEYS-32196:Fixed a crash in Migration Tool
                                            KEYS-31957:Fixed a crash when initializing denoiser
                                            KEYS-31954:Fix crash when merging triangle meshes with vertex colors
                                            KEYS-31893:Fixed a crash that could occur on multi-GPU setups when GPU0 is disabled
                                            KEYS-31738:Fixed a crash related to cache of library used for Image I/O
                                            KEYS-23966:Fixed improper scaling of Animations when changing Scene Unit
                                            KEYS-28515:Added Progress bar to Re-tessellate tool when pressing "Apply"
                                            KEYS-27607:Fixed incorrect split of objects in "Split Object Surfaces" tool
KeyShot Web Viewer
New Features
                                            KEYS-31469:New material model adopted for scenes uploaded with KeyShot Studio 2024.2
Bugs
