Color Management
Compensate for Image Gamma when applying Library Colors
Gamma corrects color values when applying them to a material directly from the Color Library. This will try to keep the appearance of the color in the Library. With this option selected, the color of the material in the Real-time View and in the Library will always match, if you don’t change the Image Gamma after applying the color.
Monitor Color Management
From 2023.1 and forward KeyShot Studio will be using the Color Profile you have set in your OS settings.
This should also help with ensuring consistency with other software.
