What does Set Camera Target do?
With the Set Camera Target tool you can select the point to where the camera is oriented.
When you have selected a camera target, Tumble will revolve the camera around this point and Dolly will make the camera move closer/farther away from it – even if the camera has been panned, so the target is no longer in the center of the Real-time View.
You can set the camera target in 2 ways:
- via the Tool
- via the Real-time View Context menu
How to Set Camera Target with the tool
- Launch the
Set Camera Target tool in the Tools section of the Ribbon. This will bring out a widget, where you can choose what you want as your camera target:
- Select what to target
- Point: This will make the clicked point on the surface, the camera target.
- Model: This will make the center of the clicked model, the camera target – note that all groups in the Scene Tree are considered models, but Set Camera Target will use the top level model.
- Part: This will make the center of the clicked part, the camera target.
- Click in the scene to set the camera target.
- when you are happy, close the tool by clicking the green check mark
. If you want to revert to the camera target from before the tool was launched, clock the red
Set Camera Target via the Real-time View context menu.
- Right click an object
- Select Select Camera Target this will make the clicked point on the surface the camera target.
