The Vertex Color texture is used only with geometry imported from other 3D applications that supports vertex color texture maps, such as ZBrush. Only use this texture if you are importing from a compatible 3D application, as it will have no affect otherwise.
Default color
controls the background color that is used for the alpha channel from an imported vertex texture.
Multiplier
Blend a color with the imported vertex color texture.
