Release Notes 2025.2
This release has the following new features, improvements, and security/bug fixes.
Security Fixes
KEYS-35173: Resolved ZDI-CAN-26473
KEYS-34994: Resolved CVE-2025-43964
KEYS-34993: Resolved CVE-2025-43963
KEYS-34992: Resolved CVE-2025-43962
KEYS-34991: Resolved CVE-2025-43961
KEYS-34815: Resolved CVE-2024-32619
KEYS-34814: Resolved CVE-2024-32618
KEYS-34813: Resolved CVE-2024-32617
KEYS-34812: Resolved CVE-2024-32616
KEYS-34811: Resolved CVE-2024-32615
KEYS-34810: Resolved CVE-2024-32614
KEYS-34809: Resolved CVE-2024-32613
KEYS-34808: Resolved CVE-2024-32612
KEYS-34807: Resolved CVE-2024-32611
KEYS-34806: Resolved CVE-2024-32610
KEYS-34805: Resolved CVE-2024-32609
KEYS-34804: Resolved CVE-2024-32608
KEYS-34803: Resolved CVE-2024-32607
KEYS-34802: Resolved CVE-2024-32606
KEYS-34801: Resolved CVE-2024-32605
KEYS-34800: Resolved CVE-2024-29166
KEYS-34799: Resolved CVE-2024-29166
KEYS-34798: Resolved CVE-2024-29164
KEYS-34797: Resolved CVE-2024-29163
KEYS-34796: Resolved CVE-2024-29162
KEYS-34795: Resolved CVE-2024-29161
KEYS-34794: Resolved CVE-2024-29160
KEYS-34793: Resolved CVE-2024-29159
KEYS-34792: Resolved CVE-2024-29158
KEYS-34791: Resolved CVE-2024-29157
KEYS-34231: Resolved CVE-2024-0111
KEYS-34230: Resolved CVE-2024-0110
KEYS-34229: Resolved CVE-2024-0109
KEYS-34228: Resolved CVE-2024-0102
More information at KeyShot CSIRT and PSIRT.
New Features
KEYS-35387: Added new “Random Texture” utility node in the material graph, that selects a random texture from a subset of textures on a per part basis
KEYS-35386: Added new “Random Value” utility node in the material graph, that generates a random value per part within a user defined range
KEYS-34954 Added new feature “AI Shots”, allowing for generation of Backgrounds, Re-styling your scene, or imagining new imagery
KEYS-34948: New Pantone colors added to color library
KEYS-34856: Added new feature “Light Layers”, allowing control over what Objects a Light affects
KEYS-34712: Added search bars to many lists
KEYS-34673: Updated the License Wizard flow
KEYS-34599: The Color Picker has received a number of improvements
KEYS-34465: Added support for GPU Rendering on AMD hardware
Improvements
KEYS-35174: Updated EULA
KEYS-35035: Updated icons for multi-material and multi-color
KEYS-35014: Improved glTF export of metallic materials
KEYS-34935: “Lock Resolution” now also disables the resolution input fields
KEYS-34912: “Curve Color Randomize” material graph node renamed to “Random Color”
KEYS-34888: Added new hotkey to deselect objects (default: Esc)
KEYS-34834: SketchUp 2025 support added
KEYS-34832: Added support for importing Maya 2026 files
KEYS-34750: Updated default hotkeys: Select Model - 1, and Select Parent - 2
KEYS-34614: Added support for the following formats:
CATIA V5 3D Read : V5-6R2025
Parasolid 3D Read : V37.1
UG NX 3D Read : NX 2412 Series (until 2412.3000)
KEYS-34610: Removed “FTP Deployment” from XR output options
KEYS-34608: New colorpicker UI supports delete hotkey/shortcut
KEYS-34583: Sub-colors can now be re-ordered in the Color Picker
KEYS-34560: Selection outlines are now always available, independent of the Scene Project tab
KEYS-33891: Improved calculation of the Scale value in Object properties
KEYS-28992: Added new “Polygon” shape to Flakes geometry node
Bugs
KEYS-35042: Fixed a crash when importing Rhino file
KEYS-35024: Fixed a performance issue when a lot of materials are changed in the scene
KEYS-34936: Fixed a bug where export to .usd, .usda and .usdc would reference textures with absolute texture paths on the users system
KEYS-34890: Fixed an issue in GPU mode when light passes through multiple translucent objects
KEYS-34879: KeyShot Web button removed from Help menu
KEYS-34849: Fixed a GPU mode crash when Tiled UV maps were missing textures
KEYS-34848: Fixed a crash in post processing of large rendered images
KEYS-34816: Fixed a bug where having multiple dots in a filename could cause glTF/b import to return without any geometry
KEYS-34758: OnShape plugin: Fixed an issue where scene would be cleared on import
KEYS-34751: Fixed a bug where Library and Project tabs could not be re-opened if they had been undocked
KEYS-34639: Navigating the list of Sub-colors in the Color Picker with the arrow keys, now switches the active Sub-Color
KEYS-34357: Fixed layering bump maps with labels not rendering correctly
KEYS-34184: Fixed truncation of many strings in Material parameters
KEYS-33955: Fixed an issue where orthographic cameras were not set correctly
KEYS-33933: Fixed setting “Only Include materials/parts with a callout” in CMF Output
