AMD Requirements
GPU raytracing in KeyShot Studio supports AMD GPUs built on RDNA3 microarchitecture or later, found in the Radeon RX 7600 or above.
We recommend:
  • A minimum of 8 GB memory
  • Driver Version: As a minimum we recommend 23.30 on Windows
Warning
If the driver version for your graphic card is not up to date the GPU icon in the Ribbon will be disabled. You may find AMD drivers here.
Multi-GPU
Multiple GPUs can be used to improve performance.
Be aware that memory sharing is not supported and the implementation does not support AMDs MGPU or CrossFire features.
Warning
Cutaway Material: Objects with the material assigned will not be visible in the viewport or when rendering.
Linux Workers: Network Rendering does not support AMD GPUs on Linux.
