Generic
The Generic material type is based on the Disney BRDF shader. When you use the Material Importer to import materials such as a Unified 3D Material (.u3m) or Substance Painter Project (.sp) their properties will be mapped to the properties of the Generic material.
Base Color
This is the surface color and can be replaced by a texture.
Metallic
Controls the “metallicness” of the material. Increasing the value will produce a more metallic appearance.
Metallic values of 0, 0,5 and 1
Roughness
This will add microscopic levels of imperfections to the surface of the material. When set to 0, the material will appear perfectly smooth and polished. When the value is increased, the material will appear rougher as light is diffused across the surface.
Roughness values of 0, 0,5 and 1.
Specular
The value determines the intensity of the reflection of light sources.
Specular values of 0, 0,5 and 1.
Specular Tint
Determines how much the color the specular reflection gets from the base color. Value between 0-1. At 0, the specular reflection is achromatic.
Specular Tint values of 0, 0,5 and 1.
Anisotropic
This value determines the amount of anisotropy. Anisotropy (the opposite of isotropy) is the property of being directionally dependent. At 0 the surface will be isotropic and will reflect light evenly. Increasing the Anisotropic value add direction to the reflections.
Anisotropic values of 0, 0,5 and 1.
Anisotropic Angle
Adjust the angle of the anisotropy.
Anisotropic angles of 0, 45 and 90 degrees.
Sheen
The perceived shininess at grazing angles on a surface. Increase the value to add sheen to the material. Primarily used for cloth materials.
Sheen values of 0, 0,5 and 1.
Sheen Tint
Determines how much the color the sheen gets from the base color. Value between 0-1. At 0, the sheen is achromatic (doesn’t tint incoming light).
Sheen Tint values of 0, 0,5 and 1.
Clearcoat
Adds a clear coat on top of the material. increasing the value will make the layer more prominent.
Clear-coat values of 0, 0,5 and 1.
Clearcoat Roughness
Controls the roughness of the clear-coat. A value of 0 will make the surface glossy while increasing the value will give the surface a satin finish.
Diffuse Saturation
Adjusts the diffuse saturation of the material. Increasing this value can make the material have fluorescent look.
Diffuse Saturation of 0, 0,5 and 1.
Advanced
Anisotropic Directio
  • UV: the anisotropy follows the UV’s on the object
  • Linear: the anisotropic direction is straight
The first material shows the UV’s of the ball. 2nd material uses UV’s for the anisotropy and the 3rd shows Linear anisotropy .
The Disney BRDF shader has values going from 0-1. In the Generic material type, we have, for artistic purposes, allowed some of the parameters to have values exceeding this.
