Layers
  • Background Color: Checking the background color will place model on a solid colored background, you can set the color here. Click the color-field to trigger a the color selector.
Using a background color in the Photographic Image style will override the Environment background setting. However the colors of the shadow will still be influenced by the environment settings. To achieve the best shadows, it is a good idea to use a black background in the environment, when using a Image Style Background color.
  • Use Frontplate: With Frontplate you can add an image layer in front of the image.
    • Add image by pressing the folder icon  or by dragging an image onto the input field either from a local folder or from the library. Supported file formats include .jpg, .jpeg, .tif, .tiff, .bmp, .png, .gif, .dds, .hdr, .hdz, .exr, .tga, .ppm, .ktx, .psd.
    • You can refresh the Frontplate by clicking the refresh icon .
    • To delete a Frontplate click the trash icon .
Images used as Frontplates will be stretched to fit the current aspect ratio.
  • Opacity – Set the opacity of the Frontplate by adjusting the slider or by entering a value from 0-1, where 0 is fully transparent and 1 is solid.
