Replace License File
If you’ve received a new license file from us, you can easily replace the old license and update the license server.
How To Replace The License File
- Save the license file to your computer.
- Launch the KeyShot License Server
- Go to the Install License tab
- Click New License
- Browse to the License file.
- The Server should now Load the License file and restart.
- If you changed the port number in the original file, Click Set Server Ports and make sure the ports are set.
Client computers will be able to connect as usual.
If your service status window does not look similar to the above image or if you are getting an error message when you start the server, you can use the troubleshooting guide for diagnosis.
