Wireframe
The Wireframe material type exposes the lines and vertices of each polygon of a surface. |
WidthControls the width of the lines (wires) in the wireframe. Width in PixelsWhen enabled, the wires are defined using pixels. When this setting is disabled, the wires are defined using scene units. Wire ColorThis controls the color of the lines of the wireframe. |
Base Color
This controls the overall color of material, excluding the wires.
Base Transmission Color
This value controls the base color transmission. A lighter color will give the appearance of transparency.
Backside Base Color
This controls the backside of the base color. On a cube this would be the inside of the cube.
Backside Wire Color
This controls the backside of the wire color.
