KeyShot Studio is a stand-alone, real-time ray tracing and global illumination program used to create 3D renderings, animations and interactive visuals. With its CPU-based architecture, photo realistic real-time rendering can be achieved on both Mac and PC, even on laptops, without the need for high-end graphics cards.
KeyShot Studio supports more 3D file formats than any other rendering software, importing over 25 different file types. It has a simple user interface with drag-n-drop material and environment presets, interactive labeling, texture mapping, physical lighting, animation and much more.
KeyShot Studio is…
Fast
Everything inside KeyShot Studio happens in real-time. KeyShot Studio uses unique rendering technology which makes it possible to see all changes to materials, lighting, and cameras instantly.
Easy
You don’t have to be a rendering expert to create photorealistic images of your 3D models. Simply import your data, assign materials by dragging and dropping them onto the model, adjust the lighting, and move the camera. Done.
Accurate
KeyShot Studio is the most accurate rendering solution for your 3D data. KeyShot Studio is built on KeyShot’s internally developed, physically correct render engine based on research in the areas of scientifically accurate material representation and global illumination.
