Edit Mode
Edit Mode enables you to modify and enhance your previously generated AI Shots. You can do so by utilizing one of the following modes.
Transform
This allows you to fine tune your images and put them into different contexts, without changing anything fundamental in your image.
Replace
Replace lets you modify specific areas of your image. This mode comes with a small tool set for painting masks on your image, to ensure only the desired areas are affected.
Fill mode - This is the brush that enables you to paint the areas you want to replace.
Erase mode - Use this to erase certain parts of your mask.
Clear the inpaint mask - Clears all masks from the image.
Upscale
This allows you to scale up the resolution of your generated images.
