Firewall Whitelist
To avoid any issues please ensure the following URLs are added to your Firewall Whitelist. Note that you might need to request help from your IT department.
The best way to do this is by using wildcards, here represented by *.
  • *.keyshot.io
  • *.keyshot.com
  • *api.keyshot.com
If that does not work, or you are not allowed to use the wildcards, you will need to add the following manually:
  • https://app.keyshot.com
  • https://auth.keyshot.com
  • https://login.keyshot.com
  • https://login-configuration.keyshot.com
  • https://cognito-idp.us-east-2.amazonaws.com
  • https://license.keyshot.io
  • https://configuration.keyshot.io
  • https://cloud-rendering-us.keyshot.io
