KeyShot Explorer
KeyShot Explorer allows you to share your scenes and view them in a browser.
Requirements
  • KeyShot Account
  • A modern GPU with access to WebGPU
  • Chromium Browser or Safari (Recommended)
You can use the following link to check if your hardware is compatible with WebGPU: https://webgpureport.org.
Tip
On a machine with both integrated graphics and a dedicated GPU, ensure that your browser is using your dedicated GPU.
To do so:
1. Go to your Graphics Settings
2. Find your browser in the Apps list
3. Set it to High Performance.
4. Restart your browser to ensure that all changes are applied.
As a last step, make sure to use the link above to verify that the correct adapter is used and compatible.
