Material Node Types
Initially, setting up material nodes is the same as setting up materials in the Material tab of the project panel. But with the Material Graph you can set up much more advanced materials using a combination of nodes. One thing you can do is add multiple bump textures to your material using Utility nodes.
All Material Types are covered in our Materials section:
