Render Output
The Output page is where you define the file specifications. The first step is to select the type of output you desire. There are four types of output:
Still Image
A static image and the default rendering output. View output options.
Animation
An animation with optional video and individual frame output.
This option is only available if there are animations in the scene. View output options.
Learn more about Animation.
KeyShotXR
An interactive KeyShotXR with all code and images.  View output options.
This option is only available if you have the KeyShot Studio Web add-on. Learn more about KeyShotXR.
Configurator
Based on the configuration set up with the Configurator Wizard you can choose to output a series of still images (+ metadata) or a webpage/iBook widget (web Configurator) where users can customize their product. View output options.
When you render a still image (or a series of stills based on the configurator) from a scene including an animation, it will render the current frame.
