Scripting: Camera Manipulation
Camera Manipulation (GUI and Headless)
Working with cameras in scripting is just like using the Camera tab in Project → Camera: You can create a camera, manipulate it to suit your needs, and save it.
>>> lux.newCamera("New")
True
>>> lux.setCameraLookAt(pt = (1, 1, 1)) # Example manipulation.
>>> lux.saveCamera()
Inspect the cameras available:
>>> lux.getCameras()
['New', 'last_active', 'default']
Choose another camera:
>>> lux.setCamera("default")
Remove the camera you just created:
>>> lux.removeCamera("New")
True
>>> lux.getCameras()
['last_active', 'default']
If you remove the active camera it will choose the “Free Camera”.
You can also set a standard view:
>>> lux.setStandardView(lux.VIEW_TOP)
The following 7 standard views are available:
- lux.VIEW_FRONT
- lux.VIEW_BACK
- lux.VIEW_TOP
- lux.VIEW_BOTTOM
- lux.VIEW_LEFT
- lux.VIEW_RIGHT
- lux.VIEW_ISOMETRIC
Setting a standard view manipulates the active camera so you could create a camera for each standard view, but remember to save them.
