Texture Node Types
Initially, texture nodes are the same as adding textures in the Material Tab of the Project panel. But with the Material Graph you can set up much more advanced materials using a combination of nodes. One thing you can do is add multiple bump textures to your material using Utility nodes.
See our Texture Types covered in our Textures section.
