HDRI Editor (Pro)
The KeyShot Studio HDRI Editor (Pro feature) is a simple way to make adjustments to lighting environments or create your own.
The HDRI Editor provides a unique system of adjustable light, image and gradient Pins to light your scene.
HDRI Editor Overview
The KeyShot Studio HDRI Editor is fully integrated into the Environment tab located in the Project window.
All Pins and settings for Color, Adjustments and Transforms are embedded in the KeyShot Studio file eliminating the need to save an individual .HDZ for each custom Environment you create. This provides a huge convenience and asset management benefit while greatly reducing the amount of data necessary to store locally and in KeyShot Studio .KSP files.
The HDRI Editor has flexible features including:
  • Export of HDR/EXR
  • Gradient Background
  • Draggable interactive Sun & Sky
  • Sun & Sky Ground Color
  • Sun Size parameter
  • Rectangular Pin Rounded Corners
  • Gradient Pins
  • Image Pin Color Adjustments
  • Extract pins from HDZ files prior to KS 7
  • Pop out HDRI Editor canvas
The following pages HDRI Editor Pins and HDRI Editor Background will take you through the settings for the HDRI Lighting environment.
