Texture Map
A Texture Map is a type of Image Map. Texture maps and their settings can be viewed in the Project  window > Materials > Textures  tab.
Adding a Texture Map
Double-click the texture Map Type (e.g. Color, Specular, Bump…) you would like to add a texture to. This will open a window where you can choose the image file to apply as a texture map. You may also drag and drop textures from the Textures library.
Removing a Texture Map
If you want to delete a Texture Map, right-click on the texture Map Type and select Delete or select the trashcan icon  next to the Texture dropdown. This will remove the selected texture from your material. If you make changes to the image file used for the Texture Map, select the Refresh icon  to update the Texture Map and see the changes. If you would like to replace the image file used for the Texture Map, select the File icon  to choose a new image file.
