Edit
These are the options in this menu.
  • Undo
    Undo previous actions. The fly-out will list the undo-able actions.
  • Redo
    Redo an action that was undone.The fly-out will list the redo-able actions.
  • Add Geometry
    Add pre-installed primitives into your scene, with just 3 clicks. These can also be found in the Model Library. You can change which models are available in this menu – see how.
  • Clear Geometry
    Clears all geometry in the scene.
  • Add Lights
    Add light sources with just 3 clicks. This menu gives quick access to:
  • Set Scene Units
    Change the set units used in the scene. For accurate results, use the same units the model was created in.
  • Preferences (PC only – On Mac Preferences are located under KeyShot Studio in the Main Menu)
    Set KeyShot Studio preferences. See Preferences for more details.
