File
These are the options in this menu.
  • New…
    Open a new blank scene in KeyShot Studio.
  • Import…
    Import a 3D file into an open or new scene. If quick import is enabled for the file type, this will import the file without showing the dialog. See the Import section for more details.
  • Import Dialog…
    This will always lead to the Import, where you can adapt the import settings for the current import.
  • Open…
    This will open a KeyShot Studio scene, or opens the import panel.
  • Open Recent
    KeyShot Studio lists the last 10 scenes that were opened/saved so you can quickly open them.
  • Save
    Save the currently open scene in KeyShot Studio (.bip).
  • Save As…
    Save the current scene in KeyShot Studio (.bip) with the option to change the name of the file.
  • Save Package…
    Save a KeyShot Package (.ksp) which includes the model as well as all associated resources (materials, environments, textures, cameras, and back and frontplates) used in a given scene.
It is very important to use the Save Package method when sharing or moving a scene across different computers, otherwise you will have problems with missing textures etc. when the scene is loaded.
  • Save for KeyShot Viewer…
    Save a KeyShot Package (.ksp) for viewing in KeyShot Viewer. The file can be Password protected and you can choose to show the KeyShot logo and/or watermark.
  • Save Active Model Sets…
    Save only the Model Set(s) displayed in order to share Model Sets with non-Pro users.
  • Localize Scene Contents
    Copy all resources used in your scene into the same folder as your BIP file.
  • Revisions Manager…
    Opens Revision Manager to preview, revert to or delete revisions. This is not enabled by default. To enable the Revision Manager, enable Backup Revisions under Edit >Preferences > General (Windows) or KeyShot Studio> Preferences > General (Mac).
  • Export (Pro only)
    Export model file to BIP/KSP,OBJ, GLB/GLTF, STL, FBX, 3MF, ZPR (win only) and USD file formats.
  • Connect to Onshape…
    Connect to Onshape is only available in the menu, if you have installed the Onshape plugin. For the use of this plugin, an Onshape account will be required. To download and learn more about Onshape, click here.
  • Upload to KeyShot Web Viewer…(KeyShot Studio Web only)
    Opens the Upload dialog for uploading to the KeyShot Web Viewer.
  • Sign out and exit
    Signs you out and exits KeyShot Studio.
  • Exit (PC only – On Mac Quit is located under KeyShot Studio in the Main Menu)
    Quit and leave KeyShot Studio.
