Material Information Manager
The Material Information Manager allows you to edit the information on your materials. The information saved to the material will be output in a table on the output document.
Library Tab
In the library tab you can edit the information on materials in the library. This way you will be able to add the information to your CMF output without having to set it up every time.
Import material
description data
This allows you to import CSV files.
Export material
description data
This allows you to export your Material Information to CSV. This way you can edit it in a table editor, for example Excel, before importing it again.
Project Tab
In the project tab you can edit the material information of the in-project materials. This means that the information is not added to the library but only used for the current project.
Customize
Material Information Schema
The Schema editor allows you to customize the material information schema. You can control which kind of information should be added by changing the title or type of the columns. You can customize the columns further by adding or deleting columns.
