AMD Requirements (BETA)
Warning
Support for AMD GPUs is currently a BETA feature. If you run into any issues or discrepancies please report them to Support at help.keyshot.com or tell us about it on the forum.
GPU raytracing in KeyShot Studio supports AMD GPUs built on RDNA3 microarchitecture or later, found in the Radeon RX 7600 or above.
We recommend:
A minimum of 8 GB memory
Driver Version: As a minimum we recommend 23.30 on Windows
Driver version
If the driver version for your graphic card is not up to date the GPU icon in the Ribbon will be disabled. You may find AMD drivers here.
Multi-GPU
Multiple GPUs can be used to improve performance.
Be aware that memory sharing is not supported and the implementation does not support AMDs MGPU or CrossFire features.
Limitations
Cutaway Material: Objects with the material assigned will not be visible in the viewport or when rendering.
Linux Workers: Network Rendering does not support AMD GPUs on Linux
