Color Mode
In KeyShot Studio's Color Mode, most of the general UI will be hidden. It allows you to have a space where you can focus on explicitly working with colors and creating Colorways.
To be able to work in Color Mode, make sure you have set up Multi-Colors first. You can set up Multi-Colors via the Color Picker or by dragging and dropping multiple colors on to a part.
Color Library
This allows you to access KeyShot Studio's Color Library. You can add new sub-colors to your existing Multi-Colors, by dragging and dropping colors from the library into the Multi-Colors listed in the Colorway panel. You can also drop them directly onto a part in the Real-time View. Note that you can only drag and drop onto a part that already has an existing Multi-Color
Colorway
Colorways allow you to mix and match Multi-Colors from different parts with each other and save that combination.
You can add a new Colorway by clicking the plus icon. The Colors shown in this Colorway would be made up of the active colors in each Multi-Color.
You can expand the view on a Colorway by clicking on it. This also allows for easier editing. Simply drag and drop any color from your Multi-Color list into your Colorway.
Colorways can also be accessed outside of Color Mode from the Ribbon. You can also add Colorways to Studios.
Output
Colorways can be added to the Queue via the Render Dialog.
