Release Notes 2025.2
Security fixes
  • KEYS-35173: Resolved ZDI-CAN-26473
  • KEYS-34994: Resolved CVE-2025-43964
  • KEYS-34993: Resolved CVE-2025-43963
  • KEYS-34992: Resolved CVE-2025-43962
  • KEYS-34991: Resolved CVE-2025-43961
  • KEYS-34815: Resolved CVE-2024-32619
  • KEYS-34814: Resolved CVE-2024-32618
  • KEYS-34813: Resolved CVE-2024-32617
  • KEYS-34812: Resolved CVE-2024-32616
  • KEYS-34811: Resolved CVE-2024-32615
  • KEYS-34810: Resolved CVE-2024-32614
  • KEYS-34809: Resolved CVE-2024-32613
  • KEYS-34808: Resolved CVE-2024-32612
  • KEYS-34807: Resolved CVE-2024-32611
  • KEYS-34806: Resolved CVE-2024-32610
  • KEYS-34805: Resolved CVE-2024-32609
  • KEYS-34804: Resolved CVE-2024-32608
  • KEYS-34803: Resolved CVE-2024-32607
  • KEYS-34802: Resolved CVE-2024-32606
  • KEYS-34801: Resolved CVE-2024-32605
  • KEYS-34800: Resolved CVE-2024-29166
  • KEYS-34799: Resolved CVE-2024-29166
  • KEYS-34798: Resolved CVE-2024-29164
  • KEYS-34797: Resolved CVE-2024-29163
  • KEYS-34796: Resolved CVE-2024-29162
  • KEYS-34795: Resolved CVE-2024-29161
  • KEYS-34794: Resolved CVE-2024-29160
  • KEYS-34793: Resolved CVE-2024-29159
  • KEYS-34792: Resolved CVE-2024-29158
  • KEYS-34791: Resolved CVE-2024-29157
  • KEYS-34231: Resolved CVE-2024-0111
  • KEYS-34230: Resolved CVE-2024-0110
  • KEYS-34229: Resolved CVE-2024-0109
  • KEYS-34228: Resolved CVE-2024-0102
More information at KeyShot CSIRT and PSIRT.
New Features
  • KEYS-35387: Added new “Random Texture” utility node in the material graph, that selects a random texture from a subset of textures on a per part basis
  • KEYS-35386: Added new “Random Value” utility node in the material graph, that generates a random value per part within a user defined range
  • KEYS-34954 Added new feature “AI Shots”, allowing for generation of Backgrounds, Re-styling your scene, or imagining new imagery
  • KEYS-34948: New Pantone colors added to color library
  • KEYS-34856: Added new feature “Light Layers”, allowing control over what Objects a Light affects
  • KEYS-34712: Added search bars to many lists
  • KEYS-34673: Updated the License Wizard flow
  • KEYS-34599: The Color Picker has received a number of improvements
  • KEYS-34465: Added support for GPU Rendering on AMD hardware
Improvements
  • KEYS-35174: Updated EULA
  • KEYS-35035: Updated icons for multi-material and multi-color
  • KEYS-35014: Improved glTF export of metallic materials
  • KEYS-34935: “Lock Resolution” now also disables the resolution input fields
  • KEYS-34912: “Curve Color Randomize” material graph node renamed to “Random Color”
  • KEYS-34888: Added new hotkey to deselect objects (default: Esc)
  • KEYS-34834: SketchUp 2025 support added
  • KEYS-34832: Added support for importing Maya 2026 files
  • KEYS-34750: Updated default hotkeys: Select Model - 1, and Select Parent - 2
  • KEYS-34614: Added support for the following formats:
    • CATIA V5 3D Read : V5-6R2025
    • Parasolid 3D Read : V37.1
    • UG NX 3D Read : NX 2412 Series (until 2412.3000)
  • KEYS-34610: Removed “FTP Deployment” from XR output options
  • KEYS-34608: New colorpicker UI supports delete hotkey/shortcut
  • KEYS-34583: Sub-colors can now be re-ordered in the Color Picker
  • KEYS-34560: Selection outlines are now always available, independent of the Scene Project tab
  • KEYS-33891: Improved calculation of the Scale value in Object properties
  • KEYS-28992: Added new “Polygon” shape to Flakes geometry node
Bugs
  • KEYS-35042: Fixed a crash when importing Rhino file
  • KEYS-35024: Fixed a performance issue when a lot of materials are changed in the scene
  • KEYS-34936: Fixed a bug where export to .usd, .usda and .usdc would reference textures with absolute texture paths on the users system
  • KEYS-34890: Fixed an issue in GPU mode when light passes through multiple translucent objects
  • KEYS-34879: KeyShot Web button removed from Help menu
  • KEYS-34849: Fixed a GPU mode crash when Tiled UV maps were missing textures
  • KEYS-34848: Fixed a crash in post processing of large rendered images
  • KEYS-34816: Fixed a bug where having multiple dots in a filename could cause glTF/b import to return without any geometry
  • KEYS-34758: OnShape plugin: Fixed an issue where scene would be cleared on import
  • KEYS-34751: Fixed a bug where Library and Project tabs could not be re-opened if they had been undocked
  • KEYS-34639: Navigating the list of Sub-colors in the Color Picker with the arrow keys, now switches the active Sub-Color
  • KEYS-34357: Fixed layering bump maps with labels not rendering correctly
  • KEYS-34184: Fixed truncation of many strings in Material parameters
  • KEYS-33955: Fixed an issue where orthographic cameras were not set correctly
  • KEYS-33933: Fixed setting “Only Include materials/parts with a callout” in CMF Output
