Release Notes 2026.3
This release has the following new features, improvements, and security/bug fixes.
Security Fixes
More information at KeyShot CSIRT and PSIRT.
New Features
  • KEYS-39035: Introducing Cloud Storage, built right into KeyShot Studio: save and open scenes, send renders and keep Library assets in the cloud without leaving KeyShot, and pick up your work on any computer you sign in to.
  • KEYS-38335: Share your scenes directly with others using the new Share flow. Recipients open the full scene in KeyShot Explorer right in their browser, with no need to install KeyShot Studio.
  • -: AI Agent (BETA): accessible directly in KeyShot Studio from the toolbar, use the new AI agent chat to make tweaks to your scene, edit materials, use your library, and render output.
  • KEYS-39006: New Part Variations: turn selected parts or a group into a variation, switch between variants (e.g. different wheels or product sizes) in the Scene Tree, filter the tree to show only variations, and render every variant from the Render Queue.
  • KEYS-36764: Organize Studios into folders: drag studios in, rename, delete and search folders, and double-click to activate a studio or expand a folder.
  • KEYS-38435: Download and install updates from a notification: follow the download progress and choose Close & Install when it's ready.
  • KEYS-39177: Choose where renders go with the new Browse button in the Render dialog, which replaces the old output-location options.
  • KEYS-38949: The queue in the Render dialog now shows where each job's output will be saved.
  • KEYS-25904 AxF materials now support displacement maps and sheen.
  • - AxF SVBRDF materials now support sheen.
  • KEYS-39664 Brazilian Portuguese added as new language for selection.
Improvements
  • -: Caustics now render faster, and converge better, in particular from environment lighting.
  • KEYS-38474 / KEYS-38986: Updated CAD import support: ACIS 2025 1.0, Creo 13.0, Inventor 2027, NX 2606 (up to 2606.4000), Parasolid V39.0, Revit 2027 and SOLIDWORKS 2026 SP3.2.
  • KEYS-39107: Added support for Alias 2027.
  • KEYS-38409: USD files exported from Substance Painter now import with their textures, including UDIMs and displacement.
  • KEYS-38237: Improved the Cinema 4D importer: imported scenes now match the results of the Cinema 4D plugin more closely.
  • KEYS-29411: Volumetric AxF materials now use their transmission roughness textures.
  • KEYS-39420: The silent install flag /NO_AISHOTS renamed to /NO_AI and now disables both the AI Agent and AI Shots.
  • - KeyShot Studio should now start more quickly.
  • KEYS-39292: Selecting a model set in the Model Sets list now selects it in the Scene Tree too, and the other way round.
  • KEYS-39309: Scene Tree: single-click activates a camera or environment, and double-click opens it for editing. Double-clicking a locked part edits its material, and double-clicking an animation opens it in the timeline.
  • KEYS-38978: Drag across the eye icons in the Scene Tree to show or hide several items at once.
  • KEYS-39011: The Scene Tree search bar now shows when a filter is on, and the filter button sits inside the search field.
  • KEYS-39344: The Model Sets sidebar now slides open and closed, and the Scene page toolbar no longer jumps around.
  • KEYS-39347: Collapsible sections now animate when they open and close.
  • KEYS-39016: Simpler Camera, Environment, Image Styles and Material lists: actions moved to the right-click menu, and a single + New button below each list duplicates the selected item.
  • KEYS-39276: The Save and Reset camera buttons now appear on the active camera's row, only when the camera has unsaved changes.
  • KEYS-39351: Save or reset a camera with unsaved changes from the camera list's right-click menu.
  • KEYS-36669: Setting a focus point in the real-time view no longer selects objects or shows selection outlines.
  • KEYS-38913: The resolution lock on the Image tab now shows an open padlock when it's unlocked.
  • KEYS-39161: Cloud Library is now called Public Library.
  • KEYS-39265: Library view options take less space, so the panel can be narrower. Refresh moved to the right-click menu and has its own hotkey.
  • KEYS-39241: Tools in the real-time view's right-click menu are now grouped in a submenu.
  • KEYS-39425: Export Mode moved from the bottom toolbar to the ribbon, next to Bake and Performance.
  • KEYS-3943:8 Share, the navigation menu and your account button stay visible when the window is narrow.
  • KEYS-38952: Scripting Console: press Up/Down to bring back previous commands.
  • KEYS-36444: When you reach your device limit, the error message now links to the page where you can deactivate devices.
Bugs
  • KEYS-31182: Fixed a crash when importing some USD files from Fusion on macOS.
  • KEYS-36671: USD import now uses the alpha channel of diffuse textures for transparency.
  • KEYS-36684: Fixed some USD files importing with a Diffuse material instead of OpenPBR.
  • KEYS-30284: Fixed missing geometry when importing some Cinema 4D files, with the importer or the plugin.
  • KEYS-36206: Cinema 4D import no longer applies textures it can't find, such as PSD files.
  • KEYS-38224: Fixed FBX cameras from Maya and Cinema 4D importing with the wrong orientation.
  • KEYS-38496: Fixed animated GLB files (e.g. SOLIDWORKS Motion Study exports) importing with wrong movement.
  • KEYS-36012: Fixed Alembic animations stopping after the model was updated.
  • KEYS-38038: The "Add to Empty Scene" import preference is now remembered.
  • KEYS-31809: Fixed some AxF materials not loading.
  • KEYS-38547: Fixed some CMYK images not loading as textures (regression since 2026.1).
  • KEYS-38656: Fixed KeyShot freezing when changing a multi-material.
  • KEYS-38725: UV Unwrap results now match earlier versions again.
  • KEYS-38775: Fixed increased noise in Interior mode on CPU and GPU (regression in 2026.2).
  • - Fixed an issue where caustics in product mode could be too bright when switching from GPU to CPU mode.
  • KEYS-38290: Fixed offline renders with denoising looking much worse than the real-time view.
  • KEYS-38212: Fixed Ground Illumination in GPU mode producing wrong alpha values, which made the background show through.
  • KEYS-38348: Fixed multi-materials rendering the same sub-material in every image when rendered from the queue, in the background, or with Network or Cloud Rendering.
  • KEYS-39057: Fixed the environment being painted at low resolution in CPU still image renders.
  • KEYS-39070: Fixed the environment being painted at low resolution in GPU animation renders.
  • KEYS-39034: Fixed scenes turning black at certain camera distances when using a scattering medium in GPU mode.
  • KEYS-39090: Fixed a red stripe on materials using the Random Color node in GPU mode.
  • KEYS-38786: Fixed a GPU mode crash caused by certain geometry (regression in 2026.2).
  • KEYS-38522: Fixed a CUDA error when selecting objects after cancelling a GPU render.
  • KEYS-38514: Fixed lighting artifacts in GPU mode when turning on model sets that contain planar lights.
  • KEYS-30630: Fixed shadow artifacts on Toon materials with high transparency.
  • KEYS-31289: Fixed faded or fully transparent objects still affecting global illumination in Interior mode on CPU.
  • KEYS-38820: The gamma hotkeys in the real-time view now change the image style gamma, and the two stay in sync.
  • KEYS-35833: Fixed Keep Focus being switched on for other cameras when you create a new camera in a scene with depth of field.
  • KEYS-39040: Fixed camera Shift being lost when rendering queued Studios.
  • KEYS-39141: When your sign-in expires, KeyShot now asks you to sign in again instead of showing a misleading "Failed to connect" error.
  • KEYS-38672: Fixed KeyShot not opening on macOS for users with long account names.
  • KEYS-36139: Sign-in on macOS now uses your proxy server for all requests.
  • KEYS-37786: Fixed sign-in failing with error N103 C0 behind some proxy servers.
  • KEYS-38805: Fixed online features failing on Macs that have invalid certificates in the keychain.
  • KEYS-37294: Fixed KeyShot freezing on macOS when a floating license server is wrong or unreachable.
  • KEYS-37913: The license wizard no longer shows an error message when nothing is wrong.
  • KEYS-37364: The license wizard no longer hides behind other windows at startup.
  • KEYS-37632: Clicks in the real-time view are no longer mistaken for drags when the mouse moves slightly.
  • KEYS-38628: Fixed marquee selection (Shift+drag) failing to select all visible objects, or selecting hidden ones.
  • KEYS-27390: Fixed parts sometimes showing the wrong selection outline.
  • KEYS-38091: Scene Tree search now finds items reliably, including with short search terms.
  • KEYS-37359: The camera right-click menu in the Scene Tree no longer shows two lock options.
  • KEYS-39328: Ctrl+G no longer groups locked objects, which could hide parts or break GPU mode.
  • KEYS-37320: Click a keyframe and press Delete to remove it again.
  • KEYS-39123: Fixed being unable to move the last animation keyframe backward by typing a time.
  • KEYS-39258: Fixed Studios being unable to switch a colorway back on after a colorway was deleted.
  • KEYS-38632: Fixed being unable to rename or move Library and Gallery folders that contain subfolders on Windows.
  • KEYS-39540: Warning dialogs now open on top of KeyShot instead of hiding behind it or appearing on another screen.
  • KEYS-38215: Fixed KeyShot Studio bringing itself to the front at random on macOS.
  • KEYS-38574: The light color picker now remembers the color space you used last instead of resetting to Kelvin.
  • KEYS-31661: Fixed panels resizing wrongly when dragged between monitors with different scaling.
  • KEYS-39255: Fixed the filename section in the Render dialog stretching when the dialog is made taller.
  • KEYS-38210: Fixed a crash when clicking a linked animation whose original had been deleted.
  • KEYS-38668: Fixed a crash when setting Ray Bounces or Global Illumination Bounces to 256.
  • KEYS-39607: Fixed a crash when adding an animation after changing KeyShotXR render settings.
  • KEYS-32197: Fixed a crash with mesh lights when a live-linked scene updates on macOS.
Other Changes
  • KEYS-38515: Due to changes in the business model form Dassault, livelinking from Solidworks is no longer supported.
Additional Release Notes
Additional Release Notes can be found here.
Cloud Rendering: Cloud Rendering Release Notes
Network Rendering: NR Release Notes
