About KeyShot Studio VR
KeyShot Studio VR allows designers, clients, and stakeholders to easily view and manipulate models, scroll through model sets, multi-materials and virtual environments to make faster, better decisions.
  1. Prepare your scene - Import CAD files into KeyShot Studio, create materials, environments, animations, cameras and save as a BIP (or KSP) file. Take into account the current KeyVR Capabilities. For more tips on setting up your scene visit the Scene Setup page.
  2. Start KeyShot Studio VR - Press the KeyShot Studio VR button in the KeyShot StudioToolbar (KeyShot 8 and forward) or launch the KeyShot Studio VR application directly.
  3. Experience - Now you can inspect your 3D model in a photo realistic rendering, and make design decisions from the animations, multi-materials, model-sets and different environments. The 3D geometry can be inspected by walking around, "flying", teleporting, selecting predefined camera and manipulating the position and appearance of individual objects in the scene.
System Requirements
The following system requirements should be understood as a rough guideline for most average users. The quality and smoothness of your experience is determined by several other factors: The complexity of your scenes (triangle count and amount of textures), the type of headset (eye resolution, field of view and preferred refresh rate) and the graphics quality settings in the KeyShot Studio VR preferences.
If you are running highly complex scenes (10+ million triangles) with a very high-resolution headset on Ultra graphics for example, you may well find that following our recommended system requirements exactly may not suffice to offer a smooth 90Hz experience. In this case you could either reduce your graphics settings in KeyShot Studio VR, especially the render scale in the custom mode, or upgrade to a more powerful GPU.
On the other hand, it may well be possible to successfully run KeyShot Studio VRon a computer with weaker components than what we list as the minimum required if you are only viewing basic scenes with a low-resolution headset and on Low graphics settings, or can tolerate a low framerate in VR.
  Recommended Minimum
Operating System
Microsoft® Windows™ 10 or later
System Memory
32GB DDR4
8GB DDR3
CPU
Intel® Core™ i7 9th generation with eight cores or equivalent
Intel® Core™ i5 7th generation with four cores or equivalent
GPU
NVIDIA® RTX™ 2070 with 8GB of DDR6 memory or equivalent
NVIDIA® GTX™ 1080 with 8GB GDDR5X memory or equivalent
Available Disk Space
800MB
800MB
