Capabilities
With KeyShot Studio VR you can, with the click of a button, bring your product into VR, enabling you to present your product in-scale, and make design decisions throughout the design process.
Our development team is continuously striving to give you the most photorealistic VR experience possible, without compromising the overall performance. On this page you can find an overview of the requirements and capabilities of KeyShot Studio VR.
General Support
| Product | Support | Comment |
PBR |
Supported |
KeyShot Studio VR features a physically based rendering engine with materials lit by an HDRI Environment. Features include environment reflection on various roughness levels on both plastic and metal-like surfaces as well as accurate color transmission on transparent objects. Refraction is approximate. |
Global Illumination |
Not Supported |
Interreflection, caustics, and color bleeding is not simulated due to performance requirements in VR. No light sources beyond HDRI environment are supported. |
GPU Hardware |
Supported |
Recommended Nvidia GTX 1080 / AMD Vega 64 or better to keep smooth frame-rate. |
Polygon Count |
Supported |
Polygon Count only limited by GPU memory, but in order to keep a smooth frame-rate we recommend aiming for 3 million or less polygons on a high-end GPU. |
File Format Support |
Supported |
KeyShot Studio VR can directly render all the file types that KeyShot Studio can import. KeyShot Studio VRitself can load .ksp or .bip. Note that the geometry has to be triangle-based. Curve-based geometry, zspheres, and NURBS are not supported (NURBS can be re-tessellated inKeyShot Studio). |
High Level Features
| Feature | Support | Comment |
Multi Materials |
Supported |
Materials within a Multi-Material can be selected via the KeyShot Studio VR tool Switch Material. |
Model Sets |
Supported |
Model Sets can be selected via the KeyShot Studio VR tool Switch Model Set. |
Environment |
Supported |
The active Environment can be selected via the KeyShot Studio VR tool Switch Environment. |
Camera |
Supported |
The camera position can be selected via the KeyShot Studio VR tool Switch Camera. Camera Settings that don't make sense in VR will be ignored e.g. spherical, field of view, shift, depth of field. |
Animation |
Supported |
Animations can be started/stopped via the KeyShot Studio VRmenu. (Long animations can take a long time to load). Fade animations are not supported. |
Locked |
Supported |
Locked parts of the scene tree and locked environments cannot be moved in VR. |
Connect |
Supported |
Users must be on the same LAN or VPN (KeyShot Studio VRConnect needs a direct connection between hosts and clients via their IP). And launch the same version of the scene, either locally or from a shared folder. |
Textures |
Supported |
Limited to image textures using one of the supported mapping types (view supported mapping types) when not baking. |
Materials |
Partially Supported |
Multi-materials and basic materials are supported (view supported material types). Baking can improve the representation of some materials. |
Image Styles |
Basic style (gamma/brightness) is supported, Photographic style not supported. |
Material Graphs |
Supported |
Support via baking. |
Studios |
Not Supported |
Configurator |
Not Supported |
Labels |
Supported |
Material Types
KeyShot Studio VR supports the most commonly used KeyShot Studio materials. Materials that are not supported will be appear as the closest matching alternative. Baking can improve the look of your materials in some cases.
| Basic Materials | Support | Comment | KeyShot Studio | KeyShot Studio VRwithout baking | KeyShot Studio VRwith baking |
Diffuse |
Supported |
Flat |
Supported |
Glass |
Supported |
Approximate appearance including refraction and IOR. Does not use roughness. |
Glass (solid) |
Supported |
Approximate appearance including refraction, IOR and thickness. Does not use roughness. |
Liquids |
Supported |
Metal |
Supported |
Baking can result in a closer match of overall color. |
Paint |
Supported |
Plastic |
Supported |
Thin Film |
Thin Film appears like regular glass without thin film effects (raises warning). |
Translucent |
Not Supported |
Translucent appears as diffuse opaque material (raises warning). Baking can result in a closer match of the overall color. |
Advanced Materials |
Advanced |
Advanced is treated as opaque plastic with diffuse, specular and roughness only (raises warning). |
Anisotropic |
Anisotropic appears isotropic (raises warning). Baking can result in a closer match of the overall color. |
Dielectric |
Supported |
Approximate appearance. |
Gem |
Gem appears like glass without dispersive effects (raises warning). |
Generic |
Supported |
Use baking for an approximate appearance. |
Measured |
Supported |
Measured is not supported without baking and objects will appear red (raises warning). |
Metallic paint |
Metallic Paint looks incorrect for high metal coverage, ignores clear-coat values (raises warning). Baking results in a closer match. |
Multi-Layer Optics |
Not |
Multi-Layer Optics appear like regular glass (raises warning). |
Plastic (Cloudy) |
Not |
Plastic (Cloudy) appears as diffuse opaque material (raises warning) or, when using baking, as tinted glass. |
Plastic (Transparent) |
Not |
Plastic Transparent appears like opaque specular plastic. Transmission is ignored (raises warning). |
Real Cloth |
Supported |
Scattering Medium |
Not |
Scattering Medium not supported (raises warning). |
Translucent (Advanced) |
Not |
Translucent (Advanced) appears as diffuse opaque material (raises warning). |
Velvet |
Not |
Velvet sheen ignores back scatter and edginess. Looks like regular specular highlights (raises warning). |
Light Sources |
Area Light |
Area Light appears as emissive. Power is ignored (raises warning). |
IES Light |
Not |
IES Light not supported. Objects appear hidden (raises warning). |
Point Light |
Not |
Point Light not supported. Objects appear hidden (raises warning). |
Spotlight |
Not |
Spotlight not supported. Objects appear hidden (raises warning). |
Special |
Cutaway |
Not |
Cutaway not supported. Objects appear hidden (raises warning). |
Emissive |
Supported |
Does not contribute light to the scene. |
Ground |
Not |
Ground not supported. Objects appear hidden (raises warning). |
Toon |
Without baking: Toon contour is ignored. Objects appear as solid base color (raises warning). |
Wireframe |
Without baking: Wireframe does not show wireframe. Objects appear as solid base color (raises warning). |
Xray |
Not |
Xray not supported. Objects appear as transparent (raises warning) or black with baking. |
Material Library Only |
Moldtech |
Supported |
Axalta Paint |
Without baking: Axalta Paint not supported. Objects appear red (raises warning). |
OpenPBR
KeyShot Studio VR supports most OpenPBR parameters visible in KeyShot Studio. Parameters that are not supported will be appear as the closest matching alternative. Baking support for OpenPBR Materials is currently limited in KeyShot Studio VR.
| OpenPBR Parameters | Support | Comment | KeyShot Studio | KeyShot Studio VR without baking | KeyShot Studio VR with baking |
| Base Weight | Supported |
| Base Color | Supported |
| Base Metalness | Supported | Does not use roughness. |
| Base Diffuse Roughness | Supported | Does not use roughness. |
| Specular Weight | Supported | Does not use roughness. |
| Specular Color | Supported | Does not use roughness. |
| Specular IOR | Supported | Does not use roughness. |
| Transmission Weight | Partially Supported | Approximate appearance. |
| Transmission Color | Partially Supported | Approximate appearance. |
| Subsurface Weight | Partially Supported | Approximate appearance. |
| Subsurface Color | Partially Supported | Approximate appearance. |
| Subsurface Radius | Partially Supported | Approximate appearance. |
| Subsurface Radius Scale | Partially Supported | Approximate appearance. |
| Coat Weight | Partially Supported | Approximate appearance. |
| Coat Color | Partially Supported | Approximate appearance. |
| Fuzz Weight | Supported | Does not use roughness. |
| Fuzz Color | Supported | Does not use roughness. |
| Emission Luminance | Partially Supported | Approximate appearance. |
| Emission Color | Partially Supported | Approximate appearance. |
| Geometry Opacity | Partially Supported | Approximate appearance. |
Texture Maps
| Map | Support | Comment | KeyShot Studioappearance | KeyShot Studio VRappearance | KeyShot Studio VRwith baking |
Label |
Supported |
Use baking or a planar mapped texture. |
Diffuse Texture Map |
Supported |
Some mapping types and options are only supported with baking. |
Bump Texture Map |
Supported |
Specular Texture Map |
Supported |
Roughness Map (In Material Graph) |
Supported |
Opacity Map |
Not |
No support for Opacity Maps. |
Texture Types
| Texture Type | Support | Comment |
Texture Maps |
Supported |
*Blend with color is not supported without baking. |
VDB |
Not |
Tiled UV |
Supported |
Use baking. |
Tri-Planar |
Not |
Video Maps |
Not |
Procedural (2D Texture and 3D Texture) |
Supported |
Use baking. |
Texture Mapping Types
Overall, only one type of mapping is supported per part.
| Texture Mapping Type | Support | Comment |
Planar Texture Mapping |
Supported |
UV Texture Mapping |
Supported |
Box Texture Mapping |
Supported |
Cylinder Texture Mapping |
Supported |
Sphere Texture Mapping |
Supported |
Camera Texture Mapping |
Partially |
Active camera is used, but does not update with moving around in VR. |
Node Texture Mapping |
Supported |
Use baking. |
Environments
| Environment | Support | Comment |
HDRI Environments |
Supported |
Full support for both data driven and procedural environments. |
Flatten Ground |
Supported |
Ground Shadows |
Supported |
Background Color |
Supported |
Backplate Image |
Not |
