Changing environment
Rotate the environment
When one of the controllers are in
Move object mode you can also rotate the environment (providing it is unlocked) Simply point the controller anywhere else than to an object, press and hold the trigger and move the controller to rotate the environment. Release the trigger when you are done.
XR Mode
If your headset supports a passthrough XR mode, this checkbox will be enabled. Toggle it on to replace the KeyShot Studio environment of your scene with your real-life surroundings.
