Windows interface
Desktop UI
Main Menu
File menu:
Open… Browse to find the scene (BIP/KSP file) you want to experience in KeyShot Studio VR.
Open Recent Lists the most recent scenes you have used.
Bake materials Toggles whether the scene you launch will show baked materials. The first time you enable this option, KeyShot Studio VRwill cache the baking data.
Remove baking cache Enables you to clear the baking data.
Preferences… Launches the Preferences dialog.
Exit Close the KeyShot Studio VR application.
Help Menu:
Report problem If you experience crashes or bugs you can let KeyShot know here.
Activate license… This option enables you to activate a different license.
Show License Information… Here you can find information about the active license.
Manual… Link to manual.
Log… Access to error/warning log.
Statistics… Access to runtime statistics of render engine.
About… Info about the current version of KeyShot Studio VR.
VR Setup
This section gives you information about the state of the headset and controllers. It also enables you to set the mode for each controller to help or guide the user in VR.
View Mode: Here you can choose between Desktop and VR viewing mode. If the headset is connected it will default to the VR mode, where the mirror window shows what the user sees in VR. If you switch to Desktop mode, you can control the camera in the mirror window with the same mouse controls as in KeyShot Studio:
Tumble: Left mouse button drag
Pan: Middle mouse button drag (Hotkey: Ctrl+Shift+Left mouse button)
Dolly: Scroll wheel (Hotkey: Alt+Right mouse button)
XR Mode: Toggles the XR mode. When XR mode is enabled, the environment is replaced with a feed from the headset’s external camera - allowing you experience your model in your current real-life surroundings. This option only works correctly in combination with XR-capable headsets.
Menu This locks/unlocks the VR Menu. Locking the Menu prevents you from accidentally switching between Tools in VR mode. You can still switch between Tools using the sidebar in the Monitor interface.
Left/Right Controller: Here you can choose the current mode for each controller and if needed switch modes. The various modes are described in the section about the VR Interface.
Scene
Here you can select what content, environment and viewing positions is used in the scene - just as you can inside VR via the controller menu. This also enables you to guide the user in VR.
Model Set: This enables you to control which Model Set is currently shown in the scene.
Camera: All cameras in the scene can be selected via this drop-down list. A click will transport the headset to that location.
Environment: All environments in the scene can be selected via this drop-down list. A click will change environment.
Screenshots: During the KeyShot Studio VR experience you can take screenshots of what you see, these will be stored in the default images folder on your PC.
Scale: Enables you to set your own size in the VR space. The slider lets you scale your own height between 1/1000x and 20x.
Units: Set the units used for the Measure tool and Snapping.
Snapping: Toggle snapping. Used in the precise move tool, measurements and in-hand object rotating.
Snapping Scale: When snapping is enabled, you can adjust the scale of the grid it snaps to.
Physics: Start or stop the scene physics. Every unlocked object in the scene is interpreted as a separate rigid physical object that can be manipulated with VR controllers in "Move Object" mode. With physics on you can experience the scene with gravity and object collision. When physics are turned off, objects will stay in the exact position where you release them when they are moved.
Gravity: The gravity slider enables you to adjust the level of gravity when physics is enabled.
Object Info: When enabled, properties of the object that the controller is pointing at will be shown, both in the desktop UI and in VR.
Animation: If the scene contains animation, the animation can be started/paused and reset to start here.
Reset Object Positions: This will reset the object positions and animation to the default values.
KeyShot Studio VR Connect
Here you can start or join a Connect session. Learn more about KeyShot Studio VR Connect.
Experience
Here you can see the frame rate of the current KeyShot Studio VRexperience. For the best experience the frame rate should always be equal to (or above) the refresh rate of the headset (typically 90hz). If the frame rate is below that, consider reducing the graphics quality in the preferences, or reducing the number of polygons in your scene.
Quality: The quality is by default set to high. Depending on scene complexity and GPU hardware you may experience low frame rates, in this case you can decrease quality to Medium or Low in order to keep a sufficient frame rate.
