What's New
AMD GPU Support
Support for AMD GPUs is no longer in Beta. Learn more about AMD Requirements.
CAD Metadata
You can now import metadata from .asm files. Learn more about Import
Cryptomatte
Support for Cryptomatte has been added and can now be rendered as a render pass. Learn more about Layers and Passes.
Custom Pivot
You can now add custom pivot points on your parts. Learn more about the Move Tool.
Depth of Field Focus
Depth of Field focus can now be kept on a focus point instead of just the focus distance. Learn more about Depth of Field.
Material Graph Improvements
The Material Graph is now dockable and has received and updated UI for a smoother workflow. Learn more about the Material Graph User Interface.
OpenPBR
Support for the OpenPBR Material has been added. Learn more about OpenPBR.
